Trans Stuck in 1st gear. Computer?
Old Nov 29, 2007 | 10:33 AM
Tonymd's Avatar
Default Trans Stuck in 1st gear. Computer?
My transmission tech says its the computer. All of a sudden when i was at lowes went to leave the check engine light came on and then the trans was stuck in 1st gear. Here is my question.
Trans tech says it needs a new computer total being $550 and says it needs to be programed.
Can i not buy one used or new already programed for my van?
Anyone else have this prob?
Old Nov 29, 2007 | 10:34 AM
Tonymd's Avatar
Default RE: Trans Stuck in 1st gear. Computer?
Forgot to mention its a 01 voyager.
Old Nov 30, 2007 | 12:42 AM
i would say speed sensors 25 each i bet teh code was gear ratio in 1st erro right??? some trans tech geee.
Old Nov 30, 2007 | 07:30 AM
Tonymd's Avatar
Ill call them today and ask what the code was. Said something about the hard drive failing.
Old Nov 30, 2007 | 08:04 AM
Tonymd's Avatar
p0605 internal pcm controller failer
Old Nov 30, 2007 | 06:11 PM
ok that would be a computer now depends if u have it in the TCM or PCM which one to replace.
Old Nov 30, 2007 | 07:25 PM
Tonymd's Avatar
He said pcm. Will i have to program it like he said or should it come already programed? Where can i find this computer?
Old Dec 1, 2007 | 10:56 AM
tgpatton's Avatar
my tranny computer went nuts at about 45mph... dropped from O/D to second gear... talk about whip-lash, luckily was not going faster... i might have needed some teeth replaced... took the dealership about three weeks and I don't remember how much $ to figure out the prob...
Old Dec 1, 2007 | 08:36 PM
master tech's Avatar
On the 2001 RS mini-van the PCM is part the TCM too. When you replace TCM you are also replacing the PCM too. You will need to flash the controller if you buy a reman..... And you need transfer the pin code for your car keys too.
Old Dec 1, 2007 | 09:47 PM
Tonymd's Avatar
How hard is this to do?
