transmission fluid in rad
hi all
i have noticed what looks like transmission fluid in my radiator and filler bottle ihave checked transmissionfluid leveland colourwhich areperfect what could this possibly be it is a grand voyager 1999 i am based in the uk any advice would be great Many thanks Dave |
RE: transmission fluid in rad
leaking radiator
thanks for that will the rad just need replacing or is it more complex than that
Suggest replacing radiator since the tranny cooler is integral to the radiator. May need to flush cooling system. If there is water in the tranny fluid, the transmission fluid may need to be changed and the transmission flushed. If there is no water in the tranny fluid, everything else is probably OK.
If the transmission fluid hasn't been changed in 50,000-60,000 miles, this would be a good time to change the transmission fluid since you will be addiing fluid anyway to the transmission upon initial start-up to fill the fluid cooler part of the radiator when it is replaced. What ever you do, use the correct Chrysler transmission fluid (According to some literature I read, ATF + 4 is backward compatable with ATF+3) Do not use Dexron in most Chrysler 4-speed automatics unless you want to be looking for a rebuilt tranny. [align=left] [/align] |
+4 is the only thing u want to put in ne way =) Does the tranny fluid loow like a strawberry milk shake? if yes then u have water in it.
thanks for that the trany fluid looks ok red but clear i will have a look at how much a rad will cost and compare it to my local garage cost to replace
Dave |
ORIGINAL: davidandkeiley i have noticed what looks like transmission fluid in my radiator and filler bottle ihave checked transmissionfluid leveland colourwhich areperfect. |
they did not put the red coolant untill 2000
have checked the fluid in rad and it does look like a milkshake . I have also checked trany fluid on dipstick and that looks ok so i think it must just be getting into the rad not the other way around .Will look into changing the rad my self as i have got hold of the manual on cd but will have to think is it worth the hassle
Dave |
Radiator @ a place like Autozone will run between $200 and $300 depending on which radiator you end up buying/ordering. labor is going to depend on where you live and the flat rate manhours is budgeted for removal and replacement of radiator and accessories.
