voyager 2007 ABS & central locking
I have a 2.8CRD and the ABS light started coming on and off over a period, it is now on constantly. had the codes read and said ABS sensor left and right error and internal error with ABS module. Is this my module failing ? If so where can it be located ? Are there any known problems with the module ?
Also a while back my battery went flat, this is all sorted now but since then my drivers rear sliding door will not lock/unlock with the fob. Have removed the IOD fuse but makes no difference. I cannot hear the soleniod working on that door. Is there anything i can do or look for to sort this out ? any help appreciated. thanks |
My ABS light has been doing the same thing! Most prob cause is dirt/rust on the pick up ABS ring!Butit doesn't bother me tbh!... Get a wire brush on it to clean it up and it will solve it...
thanks will give that a go.
| All times are GMT -5. The time now is 03:12 AM. |
