Voyager gear oil change
How do I check & top up the gear box oil on a 2004 Voyager 2.5 diesel & what oil is specified. Vehicle is in England, Don't know if that makes a difference. I can't find anything to check the level.
John
John
Chrysler specify their own ATF+4 for that gearbox. Now before you tell me its is not an auto transmission.....yes I know that. However you can put ATF in a manual and many manufacturers do.
Typically on 99% of manual transmission you check they are full by continuing to fill them until the oil just starts to run out the fill hole.
It is very important on these boxes that you change the oil very regularly e.g. every 20K miles.
Where's the filler hole located & do I need to remove the enging pan plate to get to it? That's a nuisance as I've just put it back after changing the Oil cooler hose.
Hi John
Take a look through my previous posts and you will find a link to download an official Chrysler workshop manual for your car. It will answer all your questions. I would just buy from Chrysler other wise you can go to Opie's oils, they do an equivalent.
I am not making this as a suggestion in any way shape or form but if I owned your car I would put Amsoil MTF in there. I have the older Voyager, i.,e. a 2000 model, but both my gearbox and yours are made by a German company called Getrag and both are crap gearboxes that require very frequent oil changes.
giwan
Nov 15, 2011 05:07 PM
flaxman
Sep 5, 2011 02:10 AM
rickie_doo
Jul 8, 2011 03:45 AM
