Voyager stalls
I have a 2002 Voyager that shuts off when the temp hits normal operating temp. No Idea why. A mech said to check the PCM pin (You need to test the power and ground feeds at the PCM. In the black connector pin 10 black/brown is ground, pin 20 pink gray is the switched power.
In the gray connector pin 46 orange/red is fused battery, black/dark green in pin 50 is ground.) I need a diagram of the connector to test the right wire. Thanks if anyone knows why it dies out & can point me in the right direction. |
