Water on the passenger side floor
Today I found a lake on the passenger side floor.
I think to have found the cause. For me is the A/C lower evaporator drainage. I have blown on the drainage water exit tube to clean it. Now water drops out well (in the last month I have not watched if the water drops out) I need an advice. For you i need to extend the short evaporator drainage tube with a long tube (so the water drops far to the passenger floor) ??? I need an help Thank You ! |
RE: Water on the passenger side floor
making the drain longer or cleaner does work if thats your problem. We have fixed a few that was as well
| All times are GMT -5. The time now is 03:28 AM. |
