Wiper won't wipe
I forgot to turn off the wipers after parking last night. Started the car in the morning and the drivers side wiper was frozen to the glass and didn't move.
I unstuck it and now it doesn't move properly. Moves a bit sometimes, not others; no longer in sync with the passenger side so they collide and tangle up; and sometimes moves past the edge of the window to fall across my drivers side mirror :(. Can someone advise how I can troubleshoot and fix this problem. It's a 2000 town and country. |
You'll have to remove the wiper cowl cover and investigate. Sounds like something has striped.
how to remove the cowl cover?
Seems reasonable. How does the cowl cover get removed and can you suggest what I should be looking for?
- lift off cover
- undo nut - realign the wiper on the turret - tighten nut - replace cover If you can't release the blade arm from the turret get one of these available from almost anywhere on the globe. |
