1996 Breeze A/C won't work.
Hi all, I'm new here and to owning a car (I've only had trucks).
My 96 Breeze's a/c won't work. It doesn't even blow. I switched the fuses with something else (I think the headlight fuse) and it still won't go. The light for a/c turns on so I'm assuming the fuse is good. I'm also trying to keep from pouring a ton of money into the a/c by trial and error. What is the most likely culprit? Thank you!!! |
Do you know if the AC system is full or not? That's a good place to start.
