Cirrus PCM, TCM, ECM, ECU - Plug and Play - No Dealer Trips
Our modules are Plug-and-Play. Just Put it in and Drive, no need to visit the dealer!
When you receive your part, it will be fully programmed to your exact VIN, and ready to run in your vehicle. All of the latest software updates available will be installed. No additional programming will be needed. Click here when you need us. |
Do All Replacement PCM s Need Reprogramming? 98 2.5
Do all replacement PCM s need reprogramming/flashing. I am woriking on a 98 Stratus V6 2.5. It has the black key. I understand that if both the donor PCM and the car that it is going into did not have SKIM, then no reprogramming/flashing is necessary. But, won't this change the odometer reading?
I ask because I would like have a spare PCM for diagnostic purposes. |
