Code P0301 - Cylinder 1 missfire - which is cyllinder 1?
Hi,
I have recently gotten two P0301 codes on my 1997 Chrysler Cirrus LX V6 2.5L. I'd like to change the spark plug in this cylinder but I don't know which is cylinder 1. Can anyone help me out? Or even identify if cylinder 1 is in the front bank or the back of the engine. Thank you, YiKeS |
RE: Code P0301 - Cylinder 1 missfire - which is cyllinder 1?
Rear bank, starting from thepassenger side,--1--3--5
front bank,starting from thepassenger side,--2--4--6. |
change them all out with champions
OK.... thank you. If i do want to swap them all out I have to remove the manifold on top of the engine aswell, right? And when I do this I will need to replace the gasket before I put it back on.
What is the manifold gasket part number/name I should be asking for from my autoparts store? Thanks, YiKeS |
i only have part number for chrysler parts not aftermarket ones.
thats fine I can goto the dealership, just need the part number.
