No Brake Pedal
I have a 99 Cirrus and I have no brake pedal. When the car is off and I press the pedal, it goes all the way to the floor. You cannot pump the pedal to get any pressure or better pedal. The brake master cylinder was replaced with a new one. (second time) It has been bench bleed and I have bleed all the lines to the calipers and the calipers. I have checked all the lines and cannot find any fluid leaks. Additionally, it does not appear the calipers are getting any pressure to engage the rotors. I'm wondering if the issue could be air in the ABS module?
