Rear drum brake change not right
I did my drum brakes but the right side did not work right. The self adjuster rubed on the drum. I noticed the the self adjuster where both the same on both sides. Is this right? I can take pics if needed thanx
RE: Rear drum brake change not right
yeah thats wrong u took both of them off at the same time right??? The best way i can tell u now is to get a book and go from there because to tell u whats wrong would be spinning your wheels.
What i mine both the same is that its the same part. I tryed seaching for a part # to see if the adjuster was the same or different part #'s. But found nothing.The e-bark didnt work and the pedal sinks to the floor. Than the wheel cylinder busted. So i changed the master and rear drums and wheel cylinder. Bleed all wheels and got the e-brake to work than it didnt.The left side works great. Just the right side is acting funny. And pedal still sinks and i bleed the master.
