Rear Wheel Bearing Replacement
Is the wheel bearing hub pressed on? I know I need to remove the tire, the brake drum and pry off the dust cap. Then there is a nut that needs to be removed. After that does the hub just pull off or do I need to use some sort of gear puller?
Thanks for your help!! |
