Upper and lower ball joints
Are upper and lower ball joints replaceable on the 97 cirrus without changing the whole upper or lower arms? Could also use some outer tie rod end too. How do the inner tie rods hold up? While I'm asking, how hard is it to change the front wheel bearing/hub assy? I'm in need of one of those too.
Thanks STEAK |
RE: Upper and lower ball joints
hey steak,you need to replace the whole control arm on the upper and lower!!,hub and bearing is not so easy either,heres how it bolts in as an assembly.better to get hub and bearing together.if not you'll need a press .heres goes https://w05.dealerconnect.chrysler.c...S/80151eaa.gif
