2009 T&C 3.3 Ambient Temperature Sensor
Does anyone know where can I find the steps or directions for installing the Ambient Temperature Sensor? Diagnosis Code Came up that it needed to be changed. We replaced the Air Intake Sensor but that wasn't what needed to be changed. Also could that cause the coolant to run out Daily? No leaks found. Thank you!
Ambient Temperature is outside air temp how hot it is outside the sensor is in teh vary front look between the grill area.
Okay Thank you! I found it. It's about 98 degrees daily I li e in south Florida
(Post 96255)
Coolant runs out daily with no leaks?
1. Look harder for a leak. There's a leak somewhere. 2. Check for an internal leak in the engine. Look for oil in the crankcase (motor oil looks like chocolate milk) or a blown head gasket. |
