KhryslerKid |
07-10-2011 10:29 AM |
97 Concorde 3.5 - No Spark?
I have a 1997 Concorde with the 3.5 liter engine. I drove to work the other day and after work when I went to start my car it would only turn over. It turns over fine and all the lights work too. At firstI suspected a bad fuel pump or relay. Checked on those and was getting pressure at the rail. I tried to run it on starting fluid then but it still wouldn't fire. I pulled the plug wires off at the coil and noticed I was getting no spark at the coil pack. So I replaced the coil pack and still no spark. I am new to these engines and do not know the common problems they have. I'm assuming there is a bad wire or something somewhere but I don't know where to start looking. Every now and then the check engine light flashes when the car is not running but the key is at the "on" position. I am hoping that I can read codes later in the day. But the check engine light has done that for as long as I have had it so I doubt that is the issue. ANY suggestions would be greatly appreciated!
