Crankshaft position sensor
Where is the crankshaft position sensor on a 2002 PT Cruiser Limited?
thank you
Thank you for your help
The crankshaft position sensor mounts to the engine block below the generator, just above the oil filter (Crankshaft Position Sensor—2.4L).
Remove the air cleaner lid, disconnect the inlet air temperature sensor and makeup air hose. Remove the negative battery cable. Raise the vehicle and support. Disconnect electrical connector from crankshaft position sensor. Remove sensor mounting screw. Remove sensor. |
