-   Forum Issues (https://www.chryslerforum.com/forum/forum-issues-10/)
-   -   fitting a grill (https://www.chryslerforum.com/forum/forum-issues-10/fitting-grill-6561/)
bigdenis Oct 2, 2008 07:15 PM
fitting a grill
could anyone tell me how to fit a grill to my 2005 300c,do i need to take anything from the front
of my car i am not so good at diy
Merlin Oct 3, 2008 02:30 PM
RE: fitting a grill
Yes you will have to pull the front bumper off. 3 plastic rivets in the wheel house/ arch then a 10mm bolt behind that (pointing upwards) holds the sides. Then it’s clips on top and 7mm bolts along the bottom of the bumper and 3 push pins at the bottom of each wheel house and the bumper will slide forward and off. Then you disconnect the wire harness and washer pipe. Then you remove the foam absorber so you can get to the screws that hold the old grill on and refit the new. Are you fitting the star tech grill? Or Bentley grill as we call it.
