little help please
I have a 2003 town and country and i was wondering if anybody could guide me to where i can find a "computer control wiring diagram".
can i find it at a public library.thank you |
u are looking at 80 something pages for just the pcm part. what is the issue that U have?
what supply ground to auto shoutdown relay.
is it the pcm? |
Originally Posted by valente
(Post 39783)
is it the pcm? If the ground @ Relay terminal 30 in IPM shows good ground and you have power at terminal 86 and 87, then you need to check circuit points below. Relay terminal "85" in IPM (PDC) >> IPM C3 Pin 16 (BR/WT) to >>> PCM C2 Pin 67 (BR/WT) |
the problem that im haveing is that i am not getting any spark from any sparkwire.we checked for power on injectors and had none.so we focused on the ASD relay,another thing we checked the ignition coil no power there either.so we put a jumper on the ASD and the van started.i went to the library to sign out the hanes book for the van but it doesnt have the wiring diagram that we needed.so now i think we narrowed it down to the ASD,where is it getting its ground from?is it the pcm,if it is then that could mean that the pcm is bad(i think)
Have you tried replacing the relay?
1 Attachment(s)
Here>>>>>>>>>
thanks for the replys,came to find out it was a bad (PCM)computer.
it cost me $250 to replace.thanks for the help |
