Need help with 2002 chrysler sebring convertible
Hi, I'm new to this site. I was hoping someone would be able to help me with my 2002 sebring convertible. We drove it home from work one night and everything was fine and then the next morning when we went to start it it wouldn't start. Got it started once but it died after 30 seconds and hasn't started since then. It turns over but won't catch and keep running. The battery is good and the coil packs are fine and sparking. I don't know where to start anymore.
red dot light on the dash on or flashing?
No, there's no red dot on the dashboard. The check engine light flashes five times when I turn the key to the on position the stays solid but there are no troubleshoot codes in the computer.
turn the key on and off3x the 3rd time leave it on the codes will be displayed where the miles are.
Only code I could get was P1684 saying my battery was disconnected. I'm assuming this is because I had the battery taken out and tested.
Do you know where the wires that are connected to the coil packs goes to?
u dont have a coil pack u have individual coils for each cyl. U toook the battery out after it did not start?
Yes, I took the battery out bc after I tried a bunch of stuff and tried starting it over a couple days time it started to sound like the battery was dead so I took it out to get tested and charged.
did u look any codes b4 u took the battery out?
No, I was not aware that I could check the codes like that until after I took the battery out unfortunately.
