1996 Concorde P0140 code
Hi,
I'm new to the forum. I have a question. I scanned my car and got a code of P0140, which I deciphered as Downstream O2S Stays at Center. Is that correct and what does it mean -- that is what do I have to replace. Thank you for your help. Scott |
RE: 1996 Concorde P0140 code
that 02 sensor It means the 02 is not switching back and forth like it should so it stays at center.
Does this mean I need to replace the two O2 sensors behind the catalytic converter? What do these sensors do (polution control only)? Is this a job for a handyman?
Thanks, Scott |
yep the 02 behind the cat . The sensor gives the computer the info needed to make fuel time adjustments to ge the car back to 14.7 to 1 ratio. Basicly u need them.
Scott |
One last question if you would please, what is the torque value on these O2 sensors?
Thanks Again, Scott |
good and tight they dont have one for this
I just got to down to replacing the oxygen sensors, haven't put them in yet. The car is running rough and I now get an additional code of P301 (cylinder 1 misfire). Could this be caused by the oxygen sensors code P140 or is this likely a different issue?
Thanks, Scott 1996 Concorde |
