2.7 L engine
I was told the engine in my 2002 Dodge Intrepid was made by Chrysler. That's why I'm posting here and not at a Dodge Forum. Is there a code that is generated for a low oil pressure "event"?
I'll make this short. About a month ago had my coolant system replaced. They said to replace tensioner belt also. Had replaced. Engine light came on. Had code read and it was the cam/crank. Had towed to garage and they said without even checking for codes that low oil pressure must of caused slack in tensioner chain which was the cause of engine valves being bent. Oil level was full |
no there is not a code for low oil pressure
