2001 sebring 2.7 oil recommendations.
I have an 01 sebring with the 2.7. My next oil change is in about 1000 miles at 121,000. Right now I'm using valvoline conventional high mileage and want to know if I should switch to synthetic or change brands. If synthetic what brand and regular or high mileage? Any recommendations are welcome. Please and thanks.
Tyler, everyone has an opinion on oil...
I have the same year Sebring with the same engine, albeit with less than 1/2 the mileage of your car. I run synthetic (PAO based) oil in mine for a number of different reasons, but one of the main reasons is because this type of oil resists sludging. You can't just go by the word "synthetic" on the bottle because there are different types. And you can't just go by brand names, because they all pretty much have the different groups of "synthetic" oil in their lineup. Mobil 1 EP (make sure it has the EP), Redline, Amsoil (signature series), Motul are some of the common brands. Will your car blow up if you don't use a synthetic? Probably not. (but, it is well documented that our engine is susceptible to sludge). Are the benefits to using synthetic? I believe there are. Without getting into lengthy detail (& possibly argument with someone) I'll stop here. |
Originally Posted by Thundercraft
(Post 65760)
Okay now I'm confused. I replaced my crankseal, I changed both of the belts to Gates Micro AT, and I switched to 5 quarts of Mobil 1 Extended Performance but still using Wix filters. I oil it on a test drive and floored it to see if it will squeal from first to second and second to third and its smooth and quiet but now it smells like something is burning when I get in the high RPMs. It is the new belts breaking in, new oil, new crankseal or is something wrong there?
As impossible as it is to diagnose "weird noises" over the internet, it's ten time more impossible to diagnose smells. You could be smelling a little oil that got spilled on the exhaust manifold, you could still have a leak, or it could be the car next to you that is producing a stink. It might be your shoe that is burning with your right foot that far into the throttle.
These cars were not built for the dragstrip. Take it easy and it'll last a lot longer. |
