-   General Tech (https://www.chryslerforum.com/forum/general-tech-11/)
-   -   2002 Chrysler Intrepid help (https://www.chryslerforum.com/forum/general-tech-11/2002-chrysler-intrepid-help-12713/)
roofus Oct 20, 2010 04:08 PM
I just bought a 2002 Chrysler Intrepid r/t . It is semi automatic, so I have to change 1,2,3,4 gear, but I hear it can be fully automatic, is this true? and if so how to change it so I just can put it in Drive and go, not worrying about switching gears?
Thanks in advance.
CHRYSLER TECH Oct 20, 2010 09:10 PM
its called auto stick if U have it in D it will shift for u or U can change the gears on your own its just a fun thing that's all
roofus Oct 21, 2010 12:30 AM
Thanks yeah I got it! I don't know how to work the different speeds, I first gear I would go uphill and below 20 then 2nd for 40km and 3rd for 50 and I never used 4th... was this right at all or am I off?
CHRYSLER TECH Oct 21, 2010 03:59 AM
read your owners manual
dcotter0579 Oct 21, 2010 11:10 AM
Put it in D and let it shift automatically. Observe where it shifts, RPM and vehicle speed. If you insist on shifting manually, shift at approximately the same points. Use all the gears when they are appropriate or you will put additional and unnecessary stress and wear on the engine, and waste gas.
