2005 pacifica 3.5L p0131 bad cpu?
Old Feb 9, 2024 | 04:49 PM
05pacifica3.5's Avatar
Default 2005 pacifica 3.5L p0131 bad cpu?
I bought a brand new denso oxygen sensor for my 2005 pacifica 3.5L but this p0131 code keeps immediately popping up. So I tested the sensors Ohms and it was good. I then tested the 4 wires on the harness and all tested good except for the brown wire I'm not getting 12v there. I looked at the wiring diagram and the heater 12v comes directly from the computer so I backprobed that wire from the computer with the key on and I still don't have 12v so I know the wire is not broken anywhere near the oxygen sensor.
So my question is can I run a direct 12v feed to my upstream oxygen sensor and will that make it throw the same code or any code or do i just have to figure out who sells a computer or who can fix my computer or what else can I check? Thank you.
Old Feb 9, 2024 | 08:25 PM
Default diog
Run threw this first
File Type: pdf
d0naldashw0rth
Apr 16, 2018 03:25 PM
Oklahoma1437
Apr 4, 2018 06:36 PM
shannonmci
Sep 16, 2011 06:00 PM
scfcarla
Jan 13, 2009 08:21 AM
burgess603
Nov 10, 2008 03:54 PM
