2007 Sebring drivers door won't open
hi
Drivers door won't open I have tried disconnect and reconnect battery with no luck. Any ideas Thanks in advance |
Originally Posted by nut430
(Post 87183)
hi
Drivers door won't open I have tried disconnect and reconnect battery with no luck. Any ideas Thanks in advance What exactly are you experiencing, a locked door that won't release? Please provide more details. |
All doors unlock and open other than drivers door. Tried disconnecting battery and reconnecting but still won't open. Today I wiggled the wiring harness under in the drivers kick panel to which the alarm sounded and the door finally now opens. This has happened more than 3 times in the last 12 months. The last time I it happened I disconnected and reconnected the battery and it fixed it. I have spoken to the dealer to which they have no idea on the problem. Is there a software issue? I have looked online and found that there are other people with this issue. Any ideas
(Post 87207)
Check where the harness goes into the door. The flexing of the harness at that point can result in a broken wire.
