91 Lebaron struts
Old Oct 4, 2009 | 02:00 PM
dons12's Avatar
Default 91 Lebaron struts
I went to replace the front struts. The strut assembley slammed down (spring compression pushed it down hard) when I removed the bolts for it. I went ahead and replced the strut and now I cannot get the assembly back in. It is as if the spring has stretched or something. It is the right strut for it, but the whole assembly seems too long. Even when I took it out it expanded very far.
Any ideas?
Old Oct 4, 2009 | 03:35 PM
I can't figure out what you are asking. Did you try to disassemble the strut without using a spring compressor? You must use a spring compressor to compress and hold the spring while disassembling the strut. You can kill yourself if you don't do it properly.
Old Oct 4, 2009 | 07:28 PM
22chrysler's Avatar
darn Darwinizm didn't take effect.
Old Oct 5, 2009 | 06:35 AM
dons12's Avatar
Default more info
I took the top 3 nuts off and then when I took the bottom 2 bolts out, the assembly extended out about 3 inches. It is like the whole assembly is too long. I can't get it to fit back in. I don't know if I take off the sway bar I might get a liitle more play in it. I have done about 4 sets of struts and never heard or seen this before.
Old Oct 5, 2009 | 07:49 AM
22chrysler's Avatar
good to hear you did it the right way, now question is what brand struts need a part number too. should be stamped in the housing if you don't have the box.
otherwise did you try to use a pry bar and push down on the control arm? if this is difficult, remove the 4 bolts that attach the sway bar to the control arm and rotate the bar away from the control arms. do NOT remove the bolts to frame.. these tend to break off then your sol.
Old Oct 19, 2009 | 02:31 PM
Neretees73's Avatar
It is a little late for you, but Steve Simpson who posts on here has made the correct style and pressure struts for about the same .
Old Nov 3, 2009 | 06:32 PM
Neretees73's Avatar
i have a set of 4 srt struts does anyone know for sure if the rear struts will fit i have drum breaks and the srt has disc. i could use some help from anyone who has done this before i order my springs.
Hi_Def
Mar 14, 2008 09:41 PM
acmectec2001
Oct 20, 2007 11:56 AM
TEF
Jul 18, 2007 06:07 PM
69Datsun240Z
Apr 9, 2007 11:51 PM
BLACK JACK
Nov 9, 2005 07:34 PM
