94 Chrysler Lebaron starting problems
Hi,
I have a 94 Chrysler Lebaron v6. For the past few weeks, the car won't start in the mornings. It revs and catches for a few seconds only to die. If I spray starting fluid in there, it will eventually start (very roughly and only if I hold down the gas) and I can drive it for the rest of the day with no problems, but without fail, the next morning it won't start again. I've had a tune up, and it did nothing. I also tried fuel injector cleaner and dry gas. My fluids are all at the right levels. I don't have a reliable mechanic at the moment and am at my wits end trying to figure out what this could be. Anyone else ever have this problem? Any ideas what else this could be? Thanks |
RE: 94 Chrysler Lebaron starting problems
Not sure about your LeBaron, but it might be OBD compliant. See if codes are available to get from it. If so, post them.
If not, look toward your EGR system. Leaks when cold cause many problems. Also check ALL of your vacuum lines. (But especially the larger ones.) They can leak cold, but not warm. Check intake manifold for leaks. Let us know. |
