94 lhs spark problems
so the car ran great Tuesday night Wednesday morning will not start
checked the plugs they are soaked in gas, cleaned them off and check spark it was very weak and eradicate changed the cam sensor and coil pack still getting the same thing any help on what to do would be great |
Get the codes. A '94 would be an OBD I system.
Go from there. |
(Post 75262)
Go from there. which is why im stumped and because it wont start i cant get it to show me any new codes i assume |
Make sure the battery is well charged.
Check the wiring in the ignition circuit for loose connections, corrosion, broken wires. Check for dampness in ignition wires. How old are the plug wires? Make sure the spark plugs are good and properly gapped. |
(Post 75277)
Check the wiring in the ignition circuit for loose connections, corrosion, broken wires. Check for dampness in ignition wires. How old are the plug wires? Make sure the spark plugs are good and properly gapped. but yea checked the wires and plugs they are good so im still stumped changed the tps map and crank sensor today also still no run |
anyone ??
Are the cams turning? How old is the timing belt? Start with the basics.
Originally Posted by consideringapacifica
(Post 75470)
belt looks to have been changed does not look old or worn at all |
