96 ecm computer
Are the ecm and the body computer grounded by screws...also wat can cause the electric choke not to work on car??
no such thing as an electronic choke on a fuel injected car.
aw ok well i need a lil help i have a 96 chrysler cirrus car starts up idles high and cuts off and does this will not constanly run i have recently put a new ecm in the car car wasnt getting any spark or gas and now that i put the ecm in the car this is all its doing now car was running jus fine till ecm went out im lost.
where did u get eh pcm from and is it the same part number as the on u took out?
i got the computer from a auto salvage yard part number was bot the same same numbers as the one i took off i had abn interchangable part number computer came off same year car with same size motor 96 cirrus 2.5
what were the part numbers for both
4606275 and the one i got from the yard is 4606213...somebody told me that i need to get the computer flashed/programmed because car is starting and running for bout 7-8 secs and cutting off...car will let me give it gas wen first start but cuts off in the same time frame.
it wont work no u cant just flash a pcm once the software is in there its there for good the pcm u have wont work it for a different setup then u have.
If u think u need a pcm visit autocomputerexchange.com and get the right one for your car. |
o i c cause the computer i got was supposed to be interchangeable part number from same year and make...also i lost original set of keys does the 96 cirrus have chip in key or remote
i took a look on that website in they said no parts matching that
| All times are GMT -5. The time now is 06:14 AM. |
