97 Cirrux - ABS
Hi,
I would like to know where and which fuse it is to unplug the ABS. These ABS brakes are driving me nuts during winter time. Some people told me that I can remove the FUSE so basically I'll be using the goodold brakes like in the past :) Is it true? Thanks :) |
Originally Posted by gdog_26
(Post 31529)
Hi,
I would like to know where and which fuse it is to unplug the ABS. These ABS brakes are driving me nuts during winter time. Some people told me that I can remove the FUSE so basically I'll be using the goodold brakes like in the past :) Is it true? Thanks :) If you drove your car correctly, you wouldnt have it applying. my ABS never applies when I drive in winter, but then I never need to slam on my brakes... I slow down and anticipate stopping far in advance and coast down to stops. BTW I'm in Minnesota |
I found 2 fuse about ABS, just don't' know which one to remove. Any idea?
just yank everything out. get under your car and rip out the sensors, take off the hydraulic controller and the computer then u won't have any problems until you get into bad road condtions, slam on your brakes and crash because you disabled the abs.
point is. leave it alone and drive better yourself. |
