-   General Tech (https://www.chryslerforum.com/forum/general-tech-11/)
-   -   brake issues (https://www.chryslerforum.com/forum/general-tech-11/brake-issues-34689/)
citypark007 Jul 25, 2023 07:25 PM
brake issues
I had a left front speed sensor.. no signal and left front brake sticking issue...replaced sensor and new caliper & rotor.... same issues(sensor cable read good on ohms and 12v from harness) also replaced abs module...pulling hairs advice needed..what am I missing. dont say booster it still stops on a dime and gives you change!!
ggoose Jul 26, 2023 06:58 AM
First the basics - year make/model and mileage please
With most Chryslers, the abs tone ring (toothed metal strip) is part of the wheel hub bearing. You will need to verify the tone ring is intact.
You note the front brake is sticking which I believe is a separate issue from the no signal. At times the flexible rubber brake hose will collapse internally and not allow the caliper to fully release.
citypark007 Jul 26, 2023 08:29 AM
2005 Chrysler T & C Touring 95K miles...will try changing rubber line
