-   General Tech (https://www.chryslerforum.com/forum/general-tech-11/)
-   -   CHECK ENGINE LIGHT (https://www.chryslerforum.com/forum/general-tech-11/check-engine-light-2145/)
flogirl_1752@yahoo.c Nov 7, 2006 11:51 PM
CHECK ENGINE LIGHT
hI,
i'M HAVING A REAL PROBLEM. I PURCHJASED A 1992 CHRYSLER LA BARON. I STILL HAVE TO PUT IT IN MY NAME @ THE D.M.V. I TOOK IT TO THE SMOG GUT. HE SAID EVERYTHING CHECKED OUT PERFECT EXCEPT THAT THE CHECK ENGINE LIGHT ON THE DASH IS ALWAYS ON. THERE IS NOTHING WRONG WITH MY ENGINE . IT HAS NO LEAKS AND IT RUNS FINE. WHAT I WOULD LIKE TO KNOW IS WHERE IS THE RESET SWITCH FOR THIS LITTLE TROUBLEMAKER LOCATED.tHE LIGHT STAYED ON AFTER THE TRANSMISSION OIL WAS CHANGED.
HELPPPPPPPP!!!!!!!!
CHRYSLER TECH Dec 7, 2006 07:02 PM
RE: CHECK ENGINE LIGHT
YOU WILL HAFT TO HAVE SOME ONE HOOK UP A DRB2 TO IT AND SEE WHAT IS MAKING IT COME ON. THE GUY MORETHEN LIKELY USED AN AFTERMARKET SCANNER AND IT WONT TELL U EVERYTHING THAT IS REQUIRED
