Chrysler 300 screen shuts off?
I have a 2012 Chrysler 300s and about every 14 minutes the screen will shut off or go all colourful and then shut off and turns back on a few seconds later. Also when this happens my ac shuts off and then starts blowing moist warm air. I have replaced the radio and screen but no fix. Anyone know the solution to this? |
Check connections and make sure that there are no loose ones.
If that doesn't do it, then it may be the BCM glitching. The moist air is just from condensation caused by the sudden change in air temperature. |
Yea sounds like the bcm. Do you know if it can be fixed or if it needs to be replaced and if it can be done at home? And where would It be located? |
