Chrysler Voyager Not Starting
Hoping someone can help me with an issue with my 1997 Voyager.
Unlock the car with the keyless entry remote, jump in turn the ignition on none of the gauges work go to start the car it runs for around 2-3 seconds then cuts out. The car may sit there for around 2-3 hours with the ignition off and it may start. This has happened 3 time over a year. HELP |
Two most likely issues are a dash fault (circuit board soldered joint broken) or the heater panel melted plug. Remove the heater panel and check the 21 pin plug first. If ok try tapping the top of the dash.
