Code 171
95 Ply. Neon.
Code 171 Lean Car stumbles off idle and generally lacks power. Before I get out the gages etc., any suggestions? Thanks |
RE: Code 171
P0117 ECT Sensor Voltage Too Low. I don't know how to fix that though.
-Matt- |
RE: Code 171
A bit late now but according to autodata. P0171
Intake/Exhuast leak, fuel pressure/pump, injector(s), AIR system, hose connection(s) |
RE: Code 171
code lean is not enough o2 so could ne nething from a sensor to stopped up fuel system haft to have it looked at or u would be guessing in the dark and the 2 codes u guys have are 2 different issues which one do u have 171 or 117? and then u take it u used a aftermarket scanner to pull the codes huh?? and chrysler tool would give more info
