dash lights
My dash lights all just went out I have checked all fuses they are all fine. My bright light indicator works and the odometer lights work but the rest are out.
Make sure the dimmer control is not turned all the way. That control can dim them down to nothing. If you're sure that's not the problem, it might be an inverter in the instrument cluster, depending on what year and model your car is. Search the forum here for "inverter" and see if that helps.
Also search the web for Mr. Whizard. That site might be of help to you. |
