Disable heated seat buttons in Chrysler LHS 2001
Is there a way to permanently turn off the heated seat settings? In other words, how should we disable the HI/LO heated seat buttons?
Look under the seat for a relay and unplug it.
Ok thanks. And, how do we turn on the high beams in Chrysler LHS 2001? Is there a setting for it at all? Right now, I had to push and hold the indicator handle for the high beams to stay on.
Usually, you pull the handle toward you to flash the high beams on. As soon as you release it, they go off. You push the handle away from you to turn them on. When you release it they stay on until you pull the handle back again.
That should all be covered in the owners manual. If you don't have one, keep an eye peeled for one on eBay. They come up every once in a while. |
