Heater
Old Feb 6, 2007 | 09:32 PM
fwincoltsfan's Avatar
Default Heater
I am trying to find out what the problem is with my 2005 Chrysler Sebring Limited. It is very cold outside and it go out to start the car go in and come back out in 10 minutes. I have the heat turned up full blast and it is still blowing out really cold air. I drive it and it is still blowing out very cold air. Now not until I get on the interstate and go about 70 mph does it blow out decent hot air but when I slow back down the very cold air comes back. Whats the problem? Its 5 degress below zero and I drive for a half hour to work and I can still see my breath when I am sitting in my car at work. Please help me.
Old Feb 6, 2007 | 11:12 PM
Default RE: Heater
low coolant if u have a 2.7 engine look at the heater block a little screw at the top of your engine they leak.
and with that said u will have an air bubble in the system
Old Feb 26, 2012 | 09:44 AM
samjames0507's Avatar
I have a 2001 Chrysler Sebring 3.0 and it does the same thing, i have changed the thermostat twice replaced the radiator (because someone broke where the cap screws on and tried to j.b weld it) has coolant and fuses are good..the fan works u can hear the door opens when the dial ***** are turned on the temp control as well as on the vent control. I am frustrated at this point.
PLEASE HELP!
Old Feb 26, 2012 | 01:05 PM
There are many reasons why you might not have heat. Low coolant can certainly be one of them. Plugged heater core, plugged heater hose, malfunctioning blend door, non-functioning controls.
Check the heater hoses when the car is warmed up. If the heater is working properly, both should be warm, on maybe a little warmer than the other. If one is cold and one is hot, or both are cold, then there's a blockage. It could be the hose(s) or could be the heater core.
elpaso
Cirrus & Breeze
Aug 8, 2011 05:30 PM
skywalker
Jan 22, 2011 08:19 AM
elpaso
Aug 25, 2005 01:11 AM
klownboots
Jul 11, 2005 08:24 PM
jayunit1689
May 22, 2005 01:38 AM
