no one has a solution!!!! 2000 Chrysler circus 2.4
chrysler cirrus 2000 2.4 100,000 miles
when I try to start the car it just cranks-- when I try again it starts- I put a spark plug tester between the coil and the plug no spark the first time but I do the 2nd time --I replaced the crank sensor and cam sensor and it's the same where do I go from here is there a relay in the fuse box? |
what are the codes in the computer?
There was 2 codes crank sensor and small evap leak it starts if I keep cranking with the spark tester on between the coil and plug no spark unless I keep cranking the engine thanks for responding
replace the crank sensor
(Post 100769)
ok then what is the code for the crank sensor just because the word crank sensor is in it does not mean that the issue. Need code number.
2000 cirrus
(Post 100817)
p0391 is not a valid code Look at the crank sensor wires are they full of oil?
Cirrus
(Post 100836)
no the wires are dry |
