HELP PLEASE
Hello, can someone please help me ?
My freind is ripping his hair out & throwing cash at his 2002 Grande Voyager 2.5TD Manual. The problem is :- Once the vehical gets warm it will cut out above 2000rpm, he has had the fuel pump replaced, gearbox replaced as that was crunching into gears, had it 3 times in with an auto electrician & still its doing the same thing, hes spent nearly £1000 roughly $1700 so far just trying to get this sorted and no one here in the UK seems to have any idea whatsoever about the problem or its cause & thats including Chrysler dealerships. Its showing code P1130 at the main dealers, its had the fuel pump replaced and the fuel system checked and all seems to be working correctly. Please someone help if you can, your our last hope :D Thanks |
RE: HELP PLEASE
there is an old tsb that states that if the code(p1130) is present that the fuel system has air in the line heres tsb# 18-802-01.as many times the lines have been open i would'nt be suprized.moe
