need help please with a 2.6 v6 1999 conv
it all started when i had a new battery fitted thay had problems fitting the battery as it is in the wing (it may have taken 30 to 40 mins) it started first time i drove it approx 1 mile and put in petrol it started no prob idrove it apx 15 to 20 miles took wife to a restaurant locked it for the first time was about 2 hrs unlocked car it started first time drove it approx 2 -3 mins it just cut out ran to a stop after about a hour or so it started up ran for a short time apx 2 mins and stopped got it recoverd back to home next morning it started first time did same i have checked petrol it pumped ok can u tell me the crank senor posihon and have u a wiring diagram colour code especiallyfor the e c u and what is the purple and white wire for inthe e c u all i can find is info in german the car as now been stood for 6 mths and have you a code list thanks i hope :)
soz its a 2.5 status
I'm having a little difficulty understanding. What info do you need? If you have any codes list them here.
cam sensor location chrysler stratus cabroleit
hiya
I believe it is the cam sensor that i need to sort. I have Chrysler stratus/sebring 1999 V6 2.5 convertible (cabroliet). European model I have had some info on a coupe, is this the same as the cabroleit - not sure what a coupe is? I am trying to locate the cam sensor on the above car can you help me at all? Also do you know what the purple and white wire in the ECU is for? I have had the car in the garage in spain for months now and no one seems to know Any help you can give please thanks |
as mentioned before it is the crank sensor not cam. Apologies
Hey, keep it this thread. You have like 3 others. The cam sensor IS basically the distributor itself. Crank sensor is on trans end of engine towards the back. It pokes through a hole in the transmission bellhousing and has ONE 10MM head screw holding it in and a 8 inch or so pigtail hanging off of it.
NO..the COUPE is a totally different pig. Basically same engine but different electrical system. From your first post sounds like typical crank sensor malfunction.(of course i'm not there to see the data and the DTCs) Make sure you seat it right when you install the new one. There SHOULD be a little wafer on the tip of it to set the air gap. Press it in firm when tightening the screw but don't lay on it with gorilla force. And don't let your spark plugs and wires get old. That's how distributors get killed. They are NOT cheap. |
