-   General Tech (https://www.chryslerforum.com/forum/general-tech-11/)
-   -   no washer fluid coming out (2005 T+C Van).... (https://www.chryslerforum.com/forum/general-tech-11/no-washer-fluid-coming-out-2005-t-c-van-2605/)
jasons4 Feb 17, 2007 03:39 PM
I've checked the fuse for the washer fluid motor and it's fine.
I do not hear the motor trying to pump when I activate the washer fluid squirters.
Is the pump located at the bottom of the fluid reservoir like most other ones I've seen?
Do you get at it from the passenger side fender?
Any way to test the pump?
Thanks in advance.
CHRYSLER TECH Feb 18, 2007 01:41 AM
RE: no washer fluid coming out (2005 T+C Van)....
check for power and ground at the motor use a drb to acuate the pump see if the input to the IPM is there
finlandmauri Dec 24, 2007 12:33 PM
Hi,
I have the same issue with my just-bought 2001 T&C. Chrysler Tech, I want to do what you had explained there. Could you just tell what do these mean: DRB and IPM?
Thanks!
CHRYSLER TECH Dec 24, 2007 04:59 PM
the DRB is a chryer scanner only a dealer will have this the IPM is the fuse box under the hood.
finlandmauri Dec 24, 2007 10:40 PM
thank you for clarifying! merry xmas to all!
