oil in coolant
Old Aug 21, 2012 | 11:04 AM
Emil Kvick's Avatar
Greetings, I have the same problem with oil in the cooling water, were you able to repiar your veahicle
Old Aug 21, 2012 | 11:08 AM
Emil Kvick's Avatar
H Turpy
what happened to your situvation? I have the same symptom, can you please let me know how it worked out for you, curious? Thanks Emil
Old Aug 21, 2012 | 01:22 PM
aberk80 swan's Avatar
If it's a auto, yeah... but if it's a stick he's got no oil cooler lines going into his radiator. If it's a stick, I hate to break it to you, but you have a blown head gasket. A leakdown test would confirm this.
Thanks,
Japanese auto auction agent
Old Aug 22, 2012 | 09:47 AM
imtattoo80's Avatar
For aberk80 swan
- its not 100% that it is head gasket. I had 2001 Voyager manual and i had leaking Oil Cooler.I visited 3 different garage and i got 3 answer that it is gasket BUT i did find out my self that it was Cooler. I got used one from Ebay and replaced by my self. So my problem got repaired cheap and it was easy.It took 30min.
Emil Kvick
- read from internet how to find out ways how chek cylinder head gasket. and then If you cant see any symptoms (exept oil in coolant) about gasket then you have crack in Oil Cooler.Save money and be sure before mechanic in some garage will open your engine.After what you still may have that problem
soloblazer
Jan 29, 2017 11:15 AM
Gidner
12
Sep 7, 2012 09:46 PM
Trent
11
Jul 23, 2012 03:41 PM
sassy
Jan 7, 2011 06:06 PM
Bennybone
Sep 14, 2009 04:22 PM
