P0403 & P0406 on 2005 Pacifica....
Old Jan 29, 2013 | 06:01 PM
marc386's Avatar
Can someone assist with the following please?
Hi,
I have a chrysler pacifica 2005 3.5. 4 months ago, I received 2 error codes P2305 ( Ignition Coil B Secondary Circuit) and P0302 ( Cylinder#2 misfire detected), so I changed the Coil and the car was running ok for a limited time but the RPM indicator on the right of the dashboard shows an unstability (up and down) and the sound of the engine was not stable.
Now, I have the following errors and the car does not turn on at all. Please advise and thank you.
Marc.
I have the following codes errors taken out from a scanner last week:
P0129 : Barometric Pressure Too Low
P0403 : EXhaust Gaz Recirculation Control Circuit
P0340 : Camshaft Position Sensor A Circuit Bank 1 or Single Sensor
P0335 : Camshaft Position Sensor A Crcuit
Old Jan 29, 2013 | 10:25 PM
Does it spin over any different then normal sound wise?
Old Jan 30, 2013 | 07:23 AM
marc386's Avatar
Thanks Kevin,
The engine sound after been unstable for like 10 minutes may turn back stable and normal for a little wile and then became unstable again.
FYI/ 2 weeks ago I stopped in a trafic Red light and the engine turns off and I could not turn it on again. it looks like the battery was dead and I had to tow the car and the day after, I tried to turn on the engine and the car turns on. Very strange! Thank You .
Marc
david6872
Feb 11, 2024 10:08 AM
MoParrMan
Dec 27, 2011 09:11 AM
Sarape
Oct 26, 2011 01:13 PM
luu5
Jun 5, 2008 01:57 PM
mrorange
May 23, 2008 06:05 PM
