pos cable gets hot
Old Aug 13, 2017 | 03:12 PM
bttrk's Avatar
Default pos cable gets hot
wondering if anybody has had this happen to them . working on a 2003 t&c van and after starting and driving a short way to my shop I checked the pos batt cable and it was so hot you couldn't touch it and started to smoke . I found that there are two cables spliced together one goes to the alt and the other goes to the fuse panel. the one going to the fuse panel is the one that gets hottest.
Old Aug 13, 2017 | 07:54 PM
bttrk's Avatar
messing with it today . got batt out and if I take my multimeter set for ohms I touch the black to body ground then touch the red to batt then it shows a completed curciut .
Old Aug 13, 2017 | 09:26 PM
You'll probably always get a completed circuit because there are things that are always on, such as the clock, the receiver for the remote key, maybe even the light under the hood if the hood is up while you do your test. What is important is the current that would be drawn if the battery is in place. That should be less than 50 milliamps (0.050 amperes).
Check the resistance of that red cable that was so hot. There might be a bad splice or corrosion there that is causing it to heat up.
Old Aug 16, 2017 | 09:04 PM
bttrk's Avatar
thank you .
cdyer11505
20
Jan 24, 2022 12:08 PM
paulak412
Oct 1, 2016 12:24 PM
99CHRYSLHS
Sep 19, 2010 12:41 PM
JHenry
Aug 21, 2009 10:46 PM
jalex
Cirrus & Breeze
Jun 3, 2007 06:16 PM
