Power steering pump question???
I think it is my power steering pump that needs to be replaced. It whines when I start it and when I accelerate in park it gets louder. Is my thoughts accurate about the power steering pump is the problem? Ok if so, What type of fluid does it need to be replaced with? Done some research on here and I have read that it may need ATF-4? Is that right? Last thing. Does anyone have a picture guide or a detailed direction of how to replace the power steering pump? Thanks for everyone's help! Justin
04 Pacifica 6 cyl FWD |
Yeah ATF4 is what we use now. Is it low? Do you have a leak? Check your steering rack where the boots are and see if it's leaking. I could post some pics but the forum isn't set up right and you can't see any detail in the pic attachements.
I replaced the power steering pump and it is still whinning. A little less noise but still making the noise. Does anyone know what it could be? I think i read somewhere it might be the filter but before i go after it I want to see if anyone thinks it is as well. Hope someone knows about this and can give me direction on what it might be.
It will take a day or so for all the air to get purged.
Its been weeks now. Still whinning.. Any ideas?
Have you checked anything else other than the power steering pump? Are you sure it's not the alternator or A/C compressor or a bad idler pulley? A mechanic's stethoscope can be very helpful in finding something like that.
Wrong pump
Originally Posted by markelvis
(Post 42795)
get under the car and have a friend turn the key on and off...dont start the car but listen to the fuel pump it should make noise if it is clicking on...also use a test light to test the relays....could also try juicing the pump, hook up battery pack or jumper cables to wires on pump and see if it cycles. Check your steering rack where the boots are and see if it's leaking.
The ATF-4 is need for the power steering pump that needs to be replaced. If you want to replace the power steering pump withput ATF-4 then it is possible but that give not good and the perfect advantages of is. So it is good to replace the power steering pump with ATF-4.
| All times are GMT -5. The time now is 02:51 AM. |
