recycle air and a/c switch flashing
hi guys
could anyone help got 3.3 petrol p reg voyager problem is the recycle and a/c switches keep flashing any ideas cheers |
When the AC head does it's self test (usually after a battery disconnect or a reset) and there is a failure, you will get flashing lights. Most likely it failed the cool-down portion of the self diagnostics. As in, your AC is not getting cold enough at the evaporator fin temperature sensor. Let me dig up my material on these things and i'll post more later.
good morning
thank you very much only just bought it previose owner had heating /direction switches of so will be looking for new as the one for direction just turns if turn slow it will direct to somewhere once again thanks |
CALIBRATION/DIAGNOSTICS TEST ENTRY TO INITIATE TESTS:
TO INITIATE TESTS:
RESULTS:
Test can be aborted by doing one of the following:
EEPROM DATA Calibration Diagnostics, Cooldown Status and evaporator temperature Fin Sensor values are stored in an EEPROM memory internal to the control. The microcomputer within the HVAC control module uses this information:
They left out a step in the first tests. Make sure the AC is engaged before you initiate the test. You can't always count on the control head to do it.
thanks for that off out to have a play
have a great bank holiday i owe you a pint cheers keith |
Thanks sir, I have a 1997 grand voyanger van same as this issue and I followed your structure to adjust it. It was fail. I checked A/C compressor which didn't run.How do I do to let A/C engaged?
a/s on 2001 2.5 crd limited
would i need to do this if the a/c had been regassed and battery taken out on my grand voyager 2.5 crd limited 2001? a/c didnt work so took it to be regassed, all topped up but doesnt work they say my comprressor needs replacing ?
many thanks in advance D |
