Removing Connector From Brake Light Switch (2010 Sebring)
1 Attachment(s)
Anyone know how to remove this type of connector from the brake light switch? I've tried just about everything at this point. Sheer force alone doesn't work. There has to be some type of release mechanism I'm not seeing that allows it to disconnect. I've already tried messing with the various green tabs without any luck.
Try depressing the brake pedal and then twisting the switch to remove it from the bracket supporting it. Once free from the bracket, you should be able to see how to disconnect it from the harness.
Yeah, I've already removed it from the bracket. As you can see in the picture. The problem now is removing the connector.
