Town&Country - start problems
Hi forum,
I have a Chrysler from type Town&Country 1996. In the morning I have to turn many times the key until the engine starts up. It's possible to listen the "click" from the starter but that's it. The motor will not turn on. I've changed already the starter relay but the problem keeps going. Like I told just in the morning I see this problem. Once the motor is started during the day this problem seems disappeared. Does somebody has got the same or knows may be what could be the fault? Many thanks. vasf |
Does somebody has got the same or knows may be what could be the fault? Check the cable that runs to the starter for corrosion damage, The ground cable from battery to block, and if all connections are clean and tight , remove the starter for bench testing. |
Hi Djinn-n-Tonic,
thanks for replay. The following days I will try your points and will let you know. Best regards, vasf |
